run
Dear forum members. I have a question.
How can I keep the previous data everytime. For example: after 1st run I have 1data, after 2nd run need 2nd data+1st data, after 3rd run 3data+2data+1data and etc..
I attach the Vi. Please help me.
Thanks in advise.
Sincerely
Harutyun Melikyan!
(3,200 Views)
That would be called an array of data. For best performance and if you know a priori the size of the array, allocate it with "Initialize Array" outside the while loop and use "Replace Array Subset" in your event. Otherwise, you can use "Build Array" and a functional global.
I also read your post as perhaps meaning ADDING the previous results to the current results. In that case, you could wire your current result to a shift register on the while loop.
Message Edited by Bill@NGC on 08-19-2007 07:04 PM
(3,200 Views)
Excuse me, can you attach the simple example?
My problem is: everytime need to keep all previous datas.
Thanks a lot.
Sincerely
Harutyun Melikyan.
(3,187 Views)
The quick modification shows both possibilities.
(3,182 Views)
