run time setting?
I have to modify a vi written by other.
There is a graph on the vi in edit mode. But when I run the vi, the
graph disappear.
How can I see it?
(2,664 Views)
Hi Yong,
Apparently, it's being hidden at run-time using Property Nodes. Here's how you can find and fix this part of the code: on the front-panel, right-click on your graph and select Find>>Property Nodes. This should either take you to the property node on the diagram, or bring up a box -- when there are more than one -- with the list of property nodes.
Visit each Property Node and find out if the 'Visible' property is being set to False anywhere. That's the culprit!
Adios!
Khalid
(2,664 Views)
