run sequence once a day
Hi
I want to run a sequence once a day.
To do so I found this very nice example from "altenbach" (example)
But I have several other event. And when I run those the timeout is resetted and the daily event is delayed. What can I do?
Of course I could run the "once a day"-event in a loop for itself. But I read once that there should be only one event structure in a vi.
Thanks for any help.
Yves
(3,065 Views)
Hi Yves,
i think you have to calcualte the rest time to your special event with each other event.
Mike
(3,063 Views)
Hi Yves,
here is an example for you, i think this should work.
Mike
(3,046 Views)
