run chart
Hi alllll!!!!!
       How can i plot custom x values in chart/graphs?
kavi
(3,217 Views)
You can use an xy graph. Check the help and example finder for details.
(3,213 Views)
Hi kavi,
you can write "NaN" to your chart or graph for small breaks. Otherwise see altenbach's solution.
Mike
Message Edited by MikeS81 on 01-07-2009 09:14 AM
(3,212 Views)
I really have no idea what "custom values" are. Maybe we don't understand what you want. 🙂
I am also puzzled that you mention "chart/graphs" in one breath. They are quite different
Typically you would use waveform graphs if the x values sorted and spaced equally in x (if you want to skip some values, use NaN as Mike mentioned above). If the values are spaced randomly, only an xy graph will do.
A chart is a special indicator, because it typically takes small chunks of data and it maintains a history of a defined lenght to keep the recent data.
(3,207 Views)
