rtm editor
hi
i am new to .rtm editor , some one can explain how i want to use that one.i created set of menus and i saved that one as .rtm file.
how can i use that one
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
(4,014 Views)
They have a set of icon (function) in the diagram mode to use for capting the menu selection and to manipulate the menu.
you will see the menu that you create only in run mode
Benoit Séguin
Benoit Séguin
Software Designer
(4,007 Views)
There is a really good Knowledgebase article on creating Custom Run-Time Menus here:
Creating Custom Run-Time Menus in LabVIEW
Basically, once you create the .rtm file, you would save it into the same directory as the VI and use the VIs located in the Programming >> Dialog & User Interface >> Menu function palette.  You can also see examples by opening the example finder at Help >> Find Examples...  and searching for menu.
Brian Coalson
Software Engineer
(3,994 Views)
