08-01-2005 05:02 AM
08-01-2005 05:27 AM
08-01-2005 06:57 AM
Dear all,
sorry for my intromission but I have had the same error message.
So far, what I could discover indicates that there is a problem which is system dependent.
The error pops up, at least in my case, when I haven't inicialized the port correctly because the VISA control does not find the serial port.
My application runs fine in my machine. I made the executable file and tried to run it in other machine. The thing is that I tried to run my application in another PC and I had this error message. (Both machines using Win2000 and RunTimeEngine 7.0)
After installing Labview in this other machine to be able to debug the application there I found out that the VISA control did not find any of the commports installed on that machine.
Maybe this is not your case, and your VISA control detects all your ports. In that case I guess your application is trying to run an action with the port before this one has been initialized. Try to check the flow of your application (that happened to me too).
On the other hand, if you cannot see the ports, as it is my problem, I would really apreciate if anyone could help us on finding the solution.
I've tried the "Find Visa Resources" control and depending on the machine I have run the program (all of them using Win2000), I had different results. Anyone knows why? Have you had this problem too?
Thanks a lot
08-01-2005 11:22 AM
02-08-2007 11:08 AM
02-08-2007 11:17 AM
02-09-2007 06:26 AM
02-09-2007 09:47 AM
02-09-2007 11:01 AM
