Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
08-23-2021 12:36 AM
Hi All,
I have a requirement to display calculated load values on the GUI, I need to customize the table rows as attached in the picture.
1.mainly i need to know how to merge any 2 rows in a table indicator?
2.How to create 3 coulmns inside a single row?
for example, In the below screenshot as per the requirement i need to merge 2nd,3rd,4th column for displaying Load1 similarly 5th,6th and 7th column to display Load2
Can anyone help on this?
08-23-2021 01:49 AM - edited 08-23-2021 01:56 AM
Hi Sahan,
In a LabVIEW array or table indicator you cannot merge rows/columns/cells as you are used to from MSExcel!
08-23-2021 01:56 AM
Thanks for the suggestion. I understand your points but is there any possible ways in mulitcolumn listbox to combine any rows/olumn? or any other labview feature which does this?
Also the data inside the table are not static , i need to display the calculated load values measured from different instuments under each frequencies.
Do you have any idea on this?
08-23-2021 01:58 AM - edited 08-23-2021 02:01 AM
Hi Sahan,
No.
(You may use properties like background color to mark related cells, but again: you cannot merge cells like you do in Excel…)
You can update the shown values in any kind of indicator, no matter if array, table or MCLB…
08-23-2021 05:18 PM
Of course you could use a 2D picture indicator and (with a little bit of code!) have full controls over lines, rectangles and text. 😄
