round trip time
hello everyone
iam new in labview and i wish i find some help here
iam trying to measure a ruond trip time of a wireless client/server scheme (packet_end_to_end delay)
i need ur advices in how designing the algorithm
thanks for all in advance
(3,487 Views)
Hi Mosul,
What type of client/server are you planning on using and how are you going to acquiring this client/server data? How will LabVIEW be communicating with this client/server?
Sarah Yost
Senior Product Marketing Manager
(3,427 Views)
thank u very much for ur reply
iam trying to examine the applicability of using WLAN in control systems, so i try to control a servo motor remotly by WLAN. I need to determine the round trip time(packet_end_to_ end delay). i had completed my system design but i need an algorithm to determine RTT.
thanks for ur efforts in advance
(3,401 Views)
Hi Mosul,
I found this article talking about methods of measuring RTT over WLAN.
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBQQFjAA&url=http%3A%2F%2Fciteseerx.ist.psu.edu%...
Hope that helps!
Sarah Yost
(3,380 Views)
hi Sarah
iam very thankful for ur help. the article will help me in designing the algorithmit is very useful. i need to determine the RTT using labview and  i will be very thankful for ur efforts if u give me some hints in which type of timer that helps me
thank u in advence
(3,368 Views)
Hi mosul,
I'm not sure what your application is, but using ping returns round trip times. You could use Labview to make a system call to ping, output that to a file, and then parse that back into labview with file I/O and string editing calls. The system call would be as simple as:
ping 127.0.0.1 > myFile.txt
this could then just be read into labview. No need to do more work than necessary 🙂
Cheers!
TJ G
(3,349 Views)
