rotating and measuring
I am rotating something that is using write to digital port.vi and measuring something. What happens? Does the rotating stop for a split scecond to take measurements or measurements can be taken while it is rotating. Can labVIEW do two things at the same time?
(3,374 Views)
Can labVIEW run while taking measurements without stopping?
(3,370 Views)
It depends on the details of your system, I think.  If your I/O board supports simultanious input and output, then you certainly can move and measure at the same time.  The program sends a "move this much" instruction and while it is moving, the CPU is free to perform whatever measurements you want.
I gather by your question that you are looking for a more detailed answer.  Perhaps you can provide some details yourself.  What hardware are you using?  What sort of measurement are you looking for?  Do you have some example code you are working from, or are you starting from scratch?
(3,365 Views)
