rotate array 90 degrees
I have an array of boolean indicators (relay on-off) that I would like to rotate 90 degrees. Not the label the array on the front panel.
Message 1 of 9
(11,747 Views)
Resize to one element and stretch e.g horizontal if previously stretched vertical.
André (CLA, CLED)
Message 2 of 9
(11,745 Views)
Hi bassinbc
Please see the attachment, is this what you are looking forSmiley WinkSmiley Wink..
Thanks & Regards,
Rajan
Message 3 of 9
(11,740 Views)
Or mayby like this depending on what you are after precisely.  You could probably do this with less code using the reshape array function.
Craig
LabVIEW 2012
Message 4 of 9
(11,728 Views)
And if you are interested in rotating a 2D array, have a look at this recent post.
Message 5 of 9
(11,724 Views)
Thanks, just what I needed.
Message 6 of 9
(11,702 Views)
Here's a link to the LabVIEW 8.5 VI as originally posted in this thread.
ArrayTransformations.vi (28kB)
Message 7 of 9
(11,547 Views)
I hava a other program:
Message 8 of 9
(10,463 Views)
The problem with this solution is the fact that arrays are constantly resized in memory, requiring expensive new buffer allocations. While your code is OK for small arrays, there will be a significant performance penalty with larger inputs. My code is optimized to do the bulk of the operations "in place" and will be significantly more efficient.
Message 9 of 9
(10,345 Views)
