roi in xy plot
how do I plot xy data between two cursor (a ROI) in another xy plot?
(3,538 Views)
Daquiry,
There is no specific way to specify an ROI filtration in LabVIEW. The only way I know to accomplish this would be to pass your data though your own code that would keep the data points of interested and reject the others. This is a good question. I would be curious to know if other NI customers need this kind of functionality.
Charlie M. CLD
(3,523 Views)
I think you would use property nodes for the cursor position values and use them with the array subset command to grab a portion of the original data. I assume you have an array of clusters.
(3,505 Views)
I ended up doing something like unclebump suggested.  Here's my solution.
(3,473 Views)
