rohde
Dear all;
How can I make the design of a pilot of an instrument ("In general : any insrument  ")  wich I know his SCPI language ?
Please I want the procedure as detailed !
Thank you
(2,727 Views)
Hi za3im_ensa
You can write the ASCII SCPI commands directly to the device; a good example of doing this over GPIB can be found in "Help > Find Examples > Hardware Input and Output > GPIB > LabVIEW-GPIB.vi".
Alternatively, you can search for your instrument drivers in "Help > Find Instrument Drivers..." - if a driver set exists for the device you can often eliminate some of the complexity of reading and writing the commands directly.
Hopefully this helps you get started!  If you have any other questions I'd be happy to help.
Peter D
(2,713 Views)
Thank you dear for your answer which will surely help me.
Now, it's possible to build my own driver such as those you put in your Website ??
If yes, I beg tell me how !
regards
(2,709 Views)
Accepted by topic author za3im_ensa
You're welcome!
It is possible for you to create your own 'plug-and-play' drivers and I have found some references for you.  There is a Developer's Zone article covering the development of instrument drivers; this includes good practices and driver structure.  There is a larger document covering similar material here.
Peter D
(2,704 Views)
