robotics
can I get any information regarding the movement of self balancing robot using labview .
i am facing problem in adjusting the orientation and pid values.
(1,900 Views)
Hi chai,
This is a typical student problem, asked quite often here in the LabVIEW board and elsewhere…
You will find information about this problem in a lot of books regarding control loops!
@chai1999 wrote:
… using labview .
As this is asked quite often (students seem to tackle this problem every year) you should start to search for older threads in this board and read them.
And you should describe the problems you have with orientation and PID gains…
(1,879 Views)
