robotics
I have been assigned a project that should be able to navigate, avoid obstacles and handle objects. I have to use NI-Myrio and Labview to complete the project. Since I am new to robotics and Labview, I have limited idea to approach the project. Basically, the robot needs to get inside a room and pickup object while avoiding obstacles and again, get outside of the room from a different door and drop the objects in drop zone.
(3,308 Views)
So how far have you gotten on your class project? Any ideas at all?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,296 Views)
I have some ideas relating to use of sensors ie using ir or ultrasonic range finders to navigate . Still, i dont thonk i can achieve the target without image processing.
(3,293 Views)
Hi, mike
I will be updating if i make any progress on the project.
(3,278 Views)
In general I would agree, but there are different levels of "vision". You have cameras, line cameras, optical transistors, all offering varying kinds of vision. Even ultrasonic ranging is a kind of vision.
Mike...
LabVIEW Champion
(3,269 Views)
