robotics
how to locate or set target...for a sbRIO......plz reply.....
(2,921 Views)
Can you give some more detail in your question?  What does it have to do with "robotics" which is the subject of your message?
Also, please read How To Ask Questions The Smart Way.  You seem to have established a habit of not asking a meaningful question when you post.
(2,912 Views)
I'll agree with Ravens Fan that you really haven't given the community much of a question to answer, therefore your answers will likely be as vague as the question.
As I'm not sure exactly what you have tried or what you have working at the moment, I'm going to suggest you read through the CompactRIO Getting Started material found at ni.com/gettingstarted
In particular, here is the section regarding network communication:  Configure Your NI CompactRIO System for First Use
Cheers,
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(2,895 Views)
