ring properties
hi,
is there a possilbiity to get a reference on the ring value?
I have to react if the ring value has changed. In C# you can write ButtonX.ValueChanged...I need something like this in LabView.
THX Reen
(3,034 Views)
In LabVIEW, the structure to handle events is called event structure.
Check annex vi.
Hope it helps,
Paulo
(3,018 Views)
could you post a screenshot. i´ve only lv 6.1
(3,016 Views)
here's a pic of Paulo's vi.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,004 Views)
Just in case you are not using event structure.
This might be just another option.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,989 Views)
