right-clicking on sub-vi crashes LabView 7.0
Hello �
Please go to www.ni.com/ask and choose the E-Mail NI option to send us an email referencing this discussion forum thread. We will reply to you with the procedure.
Have a nice day.
S Vences
Message 11 of 13
(638 Views)
Hi Jon,
I have just started having exactly the same problem (i.e. right-clicking on subVIs, references  & their wiring). How did your problem work out:?
Cheers,
Kevin Giles
Siemens VAI
Message 12 of 13
(583 Views)
Hello all...
I'm just curious... 3 different people reporting the same behavior in the same timeframe (or relatively...)
This is too odd to be a mere coincidence..  Can you all provide some info such as what OS you are using? If using MS-Windoze, do you have automatic upgrades turned ON?
There has to be something that triggered this bizzare situation.  I still use LV7.0 & LV7.1 for some customers.  They both run fine on XP with SP-2.
I'm definitely interested in finding out what triggers this behavior and would suspect that there is nothing wrong with the LV installation, especially if it was running fine up to this point.
Thanks for posting this issue...  It's good to know what others are seeing in order to avoid lengthy debugging processes..  😮
JLV
Message 13 of 13
(577 Views)
