rf transciever kit
can i make pc controled robot using labview the kit is not from ni but it is usb rf transciever kit  and if yes the how...plzz give brief idea..ITS REALLY URGENT THNX
(4,848 Views)
We will need much more information about what you are trying to do and what hardware you have. It is probably possible to control your project with LabVIEW, but we need more information before we can offer suggestions.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(4,830 Views)
http://triindia.co.in/shop/product_info.php?cPath=54&products_id=96 i want to use this kit having parallel port...simply i want to control two motors from the pc using
LABVIEW as the kit is having 4 channels...so plzz help me
thnx in advance
Regrads
Gaurav Sharma
(4,820 Views)
http://triindia.co.in/shop/product_info.php?cPath=54&products_id=96 i want to use this kit having parallel port...simply i want to control two motors from the pc using LABVIEW .....
please someone help me as i mention all the problem above please give brief idea about it..
that how to load driver,configuring  and all that kind of stuff...ITS URGENT I HAVE TO MAKE PROJECT ..DATE APPROACHING :smileyindifferent:
thnx in advance
Regrads
Gaurav Sharma
(4,799 Views)
Gaurav,
Since you will be interfacing this throught the parallel port, you can go through the examples VIs in LabVIEW for parallel port programming. Can you give some more details on what type control and monitoring you will be doing.
Are you looking to control just the motors?
Rohit
(4,786 Views)
Hello Rohit,
Firstly thanks for your reply rohit, this is my first pc controlled robot that I am going to make so i am doing from basics so I am controlling only two motors and if you have experience you can suggest me that what additional I can integrate in it  even though I know the programong well.
If you can help me, you can give me your yahoo id so that i can add you to my friend list.
Gaurav Sharma
(4,771 Views)
Hi Gaurav,
I thnk that if this is only a Parport programming than you can control using the Parallel pport commmunication VI from labVIEW.
Y dont you go ahead and ask the TRI ppl if you can program it using labVIEW.
More than that what is the programming language or package that they have given along with it for communicating this board?
Anuj Bhansali
AE
NI INDIA
(4,751 Views)
