return error structure from function
I'm writing Active X application. I would like that every method would return error or no error value, the same what Labview use it. Do you have example code which explain how to do it?
(2,554 Views)
Every property node and invoke node used in the LabVIEW code to perform Active X programming has two outputs, the reference and the error cluster. The error cluster contains three pieces of information, one of which is a boolean value that shows if an error has occurred or not.
-JohnM
(2,554 Views)
