retriggerable pulse task
Hi all.
I am looking for this file.
1. Retriggerable Pulse Task
2. SCXI Analog Input Task
For your information, I was given a task to do some enhancement for my project.
However, I can't these two sub.vi from the file neither in the example.
The original program was programmed using LabVIEW 7.1. However, I am now using LabVIEW 8.6.
Those who has / found these two files, kindly share it here.
Thank you!
with regards,
Fird
(2,600 Views)
Hi Fird,
I don't think the 2 VIs you are looking for are in-built NI VIs.
Do you have the old codes in LabVIEW 7.1? You should be able to open them in LabVIEW 8.6 without any problems. Or are these 2 VIs missing from the LabVIEW 7.1 codes too?
I have searched for these 2 file names in my LabVIEW 7.1 (with both the DAQmx and Traditional DAQ driver installed) and they cannot be found so I'm pretty sure they are customized subVIs, not NI shipping examples.
Boon Chen
(2,571 Views)
