retrieve top level filename programmatically
Is it possible to retrieve the filename of the toplevel vi (that runs and is in memory)programmatically?
For example, if the top level vi is called "My Program.vi", I would like to get this name in my program for saving purposes etc. I could type in "My Program.vi" in a string, but sometimes I give the top level vi a different name, like "My Program revision 2.vi" and I would like the program to be able to retrieve that name so I can wire it to other functions
(3,335 Views)
In the file I/O pallette/file constants there is a vi called current vi's path you can use it with strip path to always return the name of the top level.
Joe
Joe.
"NOTHING IS EVER EASY"
(3,335 Views)
In the Application Control palette there is a "call chain" function which gives you the whole calling path from the top level VI to this point!
Yours Sincerely
John www.tradersmicro.com
(3,335 Views)
Thanks so much, just what i needed
(3,335 Views)
Thanks guys for your help, its working now
(3,335 Views)
