retrieve saved excel sheets from the specified path
Hi
    I've saved excel sheets in a folder programatically. Can I retrieve them  programatically by specifying the name of the
excel sheet.
          I'm using LabVIEW 2009
Regards
RobinHood
Message 1 of 19
(3,819 Views)
You'll have to be more explicit about what you have done.  Are you using the report generation toolkit?  Did you generate/manipulate the data within an excel sheet and then save the file or are we talking about a simple file transfer operation?
I'm quite sure it's the latter because if it were the former you wouldnt be having these problems 😉
Post your VI or a highlight your code on the block diagram and Edit --> Create VI Snippet from Selection.  Post the image.
Message 2 of 19
(3,816 Views)
I'm using Report generation Toolkit. I've made a sub vi(for excel) anf have put it in the main vi. This sub vi(for excel) will
Regards
RobinHood
Message 3 of 19
(3,807 Views)
I've one more thing Battler. If I generate data and save it in an excel sheet with name VPA-1(say). Next time you run the
code and if you give the same name(as VPA-1) for the excel sheet then it should ask "The file already exists, do you want
to replace it". I've made "prompt to replace button" true in "Save Report to File VI". But it is asking for every file
even if the file was not there actually.
Regards
RobinHood
Message 4 of 19
(3,804 Views)
     Can anyone help me out
Regards
RobinHood
Message 5 of 19
(3,796 Views)
For your 1st question, does this help?
http://decibel.ni.com/content/docs/DOC-3546
There is heaps of info about Excel development.  Search ni.com.
Also, have a look at the File I/O --> Advanced File Functions pallete.
Message 6 of 19
(3,784 Views)
Here's how to open Office (Excel or otherwise) if you don't have the Report Generation toolkit (such as I).
http://decibel.ni.com/content/docs/DOC-6843
Message 7 of 19
(3,783 Views)
Thanks Battler. But, I couldn't  understand "No Error"  case section of the vi. can you explain what is happening in that case.
Regards
RobinHood
Message 8 of 19
(3,743 Views)
Can you post a block diagram image so we can have a look.
Message 9 of 19
(3,704 Views)
Regards
RobinHood
Message 10 of 19
(3,696 Views)
