retrieve records from ms-access
hi,
i have done insertion and updation of values to the database. thanks for the support and guidance.
now  i want to retrieve records from database that is ms-access
i have user DB Tools Get Parameter. Is this correct?
how can i do this in labview?
Thanks In Advance
Regards
Soundarya
(2,528 Views)
Hi Soudarya,
you can use the "DB Tools Select Data.vi".
Mike
(2,525 Views)
Hi Soundarya,
If you have the Database toolkit, you can search in the example finder for databse and open the database fetch example
or else it is attached below
you can ask queries if not understood
Regards
Shrek
(2,524 Views)
