retrieve iteration from stacked sequence structure
I have a stacked sequence structure with 15 iterations. Is there a functional equivalent to the "i" from the For loop or a way to make one?
I need to trigger some other events based on what iteration of the stacked sequence is running.
Message 1 of 10
(4,665 Views)
In a sequence structure they are called frames rather than iterations.  And you have run into one of the reasons why sequence structures are usually not the best arrchitecture for involved programs: They are hard to modify and essentially impossible to branch.
You can context-click on the edge of the frame and choose Replace with Case Structure.  Enclose the case structure in a while loop.  With just a little extra effort you will have a state machine which is much more flexible.
Lynn
Message 2 of 10
(4,659 Views)
you can put numeric value 0 to case 0, then pass that value + 1 to next stack (right click the sequence structure, add sequence local). It would be better design to use state machine than sequence structure.
Message 3 of 10
(4,653 Views)
Let me first reiterate what the others have said. Avoid stacked sequences like the plague!
I have found that except for very few situations there is always a better way then using a sequence structure.
That being said you could use a local variable to do this too...
=== Engineer Ambiguously ===
Message 4 of 10
(4,639 Views)
I've convinced myself it's better to use a proper state machine.
So to do this, the best method is to have 15 serparate case structures, and place that into a while loop with N=15?
..then read the iteration number, and depending on that logic, select the proper case structure within the while loop?
Message 5 of 10
(4,631 Views)
That should be ONE case structure, containing 15 different cases.  Then you wire the iteration number directly to the ? terminal of the case structure.
Message 6 of 10
(4,627 Views)
That makes sense. thanks!
Message 7 of 10
(4,624 Views)
May I humbly suggest this article: Application Design Patterns: State Machines
You can create a state machine using the VI template that ships with LabVIEW. File -> New... Then expand the "From Template" branch.
Message 8 of 10
(4,614 Views)
In your example though, how do you get the dark bolded local variables? Or the part of the first frame that says I32 Iteration.
Message 9 of 10
(4,604 Views)
They're drawn that way automatically my setting the local variable to "read". With the addition of the little arrows (as a consequence of an idea submitted in the LabVIEW Idea Exchange) it's somewhat redundant now.
Message 10 of 10
(4,591 Views)
