07-02-2019 08:23 AM
Hello
I'm reading a jpeg image, converting it to an unflatten pixmap and plotting it to an intensity graph. Is there a way to resize the image to size of the intensity graph? I have seen similar options of resizing to a container on the front panel by using the 'zoom factor' in property node. Wondering if there is an easier way to do the same for intensity graph?
07-02-2019 08:39 AM
Hi Robin,
You are talking about the 2DPictureIndicator: it supports a Zoom factor.
When you use the front/middle/background images in graphs you need to apply the scaling using your own routines…
