resizing Listbox programatically
LV6.1
I want to adust the size of a listbox in that way, that it automatical fits into it´s FP. The user can resize the FP, so the Listbox should follow.
I know, you can poll the current size of the FP and then you ......
But is there a smarter way than polling ?
(3,007 Views)
Somewhere in the vi properties (window dimensions?) there is a special option that you can set to automatically resize objects on the FP with window resizing. Hope this can help you.
(3,007 Views)
The option is "window size" under vi properties. You can then check "scale all object on front panel as the window resizes". You can also use property nodes to increase the number of rows but not the bounds of the listbox. hope this helps
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,007 Views)
That´s in principle right, but the more often you resize the FP (>10) the more moves the listbox out of the FP frame.
(3,007 Views)
