resize the microsoft calender in labview
Hi guru,
Thanku for ur idea.its working fine
kavi
Message 11 of 14
(1,553 Views)
karpaga wrote:
 friends,
Sorry a change in my question iwant to enlarge the calender size
I attached the calender picture i want to enlarge that only.
Just to clarify: that is NOT the Microsoft calendar control. That is a custom VI that is called when you click on the little calendar control that's shown on the standard LabVIEW timestamp control. The suggestion you chose to accept as a solution uses the Microsoft ActiveX control, which is a completely different beast. That will work, but keep in mind that it will be restricted to run on Windows machines only.
Message 12 of 14
(1,545 Views)
Thank you so much GURU for your very quick & accurate reply.
Further I need to know, that how I can remove the word 'value' from indicator? i.e. it is giving "Value -> 6/1/2009" on indicator.. I just need '6/1/2009' on indicator...
Can it be possible?
Vaibhav Gandhi
B.E. Instrumentation & Control,
INDIA
Message 13 of 14
(1,492 Views)
here you go ...use the variant to data function as shown
Regards
Guru (CLA)
Message 14 of 14
(1,488 Views)
