resize intensity image based on pixel dimensions
I want to resize an intensity graph to an exact pixel-by-pixel size, but I do not see this option anywhere.  Right now I need to create a 257x256 intensity graph on the front panel, but I have no idea how to do this.  Does the graph automatically reshape the viewable area based on the dimensions of the 2d array that I provide it?
Anthony
(2,592 Views)
There is an intensity graph property available called Plot Area: Size which will set the plot area (width and height) in pixels - I think this is exactly what you are looking for.  Attached is an example of this in version 7.1, otherwise you can just right click the intensity graph on your block diagram and Create -> Property Node, and then use the operating tool on the property node to select the noted property.
Best Regards,
JLS
Best,
JLS
Sixclear
(2,587 Views)
