resize frontpannel
when i resize, my frontpannel all controls move and/or resize. simular to the resize example.
Can i set a minimum height en width for the frontpannel? for example min height=200 and width=200,your current height en width are > 200.
Can i make the frontpannel stop resize, to prevent the user from making it smaller than then minimum.
regards
johan
(3,045 Views)
Johan,
Yes, you can do this. If you go to VI Properties>>Windows Size (by right-clicking on the icon in the top-right corner), you can set the Minimum Panel Size. There you can also set to have all front panel object resized with the panel.
Under Properties>>Windows Appearance you can customize its appearance so that the user cannot resize the window.
Zvezdana S.
(3,045 Views)
yep, that's it
thanks for you answer!
(3,045 Views)
