resize build array function programmatically
Hi all,
I have been trying to programmatically resize the 'Buil Array' function by using VI scripting, but to no success 😞 I managed to create the attached block diagram with VI scripting but I would still need to programmatically wire the three refnums to the build array node...but I don't know how to add another two terminals.
Any help would be greatly appreciated,
Enrique
(3,492 Views)
When you work with the script you have to get the reference of the object that you want to play with. So once you got then you are done. Check the attached code for an example. This code expects a VI with a build array already dropped in.
(3,480 Views)
Hi P@Anand,
Thanks for your super quick reply and valuable code, which is exactly what I was looking for 🙂
Enrique
(3,463 Views)
