reseting integral function
How can I reset the integral function without resetting the labview application. The integral function is inside a “Case Structure”, it seems that I am not able to reset the output of the integral function without restarting the LabView application.
Appreciate your suggestions.
(3,116 Views)
Hi Jafar,
Thanks for posting on the NI forums.
I believe we spoke on the phone yesterday. If you are using the integral express VI, then there is a workaround to allow you to reset the algorithm. Once you have configured the express VI so it behaves as you wish, right-click the express VI's icon on you main VI's block diagram, and select 'Show Front Panel'. A dialog box will appear, noting that the express VI will be converted to a standard VI, click 'Convert' to proceed. You will be presented with a front panel which will have on it a boolean control labelled 'Reset'. By connecting this control to one of the VIs terminals on the connector pane, you will be able to wire a boolean value to the subVI on you main VIs block diagram to reset the integral function.
I hope this helps!
Rob
National Instruments | Northern California
(3,087 Views)
Maybe it's stupid question, but what is this connector pane?
(2,734 Views)
