reset graph after each run
In the attached VI file, I am trying to collect data at interverals (in secs) and display it in a graph that updates after each iteration.  However, I would like the graph to be reset just before I start a new run of the program.  In the current state, after the program ends, the graph just seems to append data and continues on.  I would like to have the x-axis as the time.  In the current state of the program, I wait 1sec, take data and so on.  I would like a plot of the data vs time.  So in the attached VI, the graph should end at 20secs.
I would sincerely appreciate any help in figuring out my dilema.  I am running LabView 8.2.
Thanks for all your help and time.
hiNi.
(6,414 Views)
You are writing to a chart and not a graph and in order to clear it, you write to it's History property. Just like the example (Help>Find Examples) 'How to Clear Charts & Graphs' show you. In the example finder, just enter 'Charts' into the search field. While you are there, look at the example called Real-Time Chart (which also uses the History property to clear the chart).
(6,410 Views)
Accepted by topic author hiNI
Like so
Andy Chang
(6,405 Views)
