representing waveform data as in an oscilloscope
I am trying to represent some data I have generated simulating the way data is shown in an oscilloscope screen. These data are waveform type, i.e., it could be data generated by multitone generator or similar. I would like to see the signal running in my PC screen from left to right or right to left in the representation just like It is shown in an oscilloscope. I guess I should use a Waveform Chart with the Strip Chart option. But I am still not able to see what I would like to see. Any advice? Thank you in advance.
(2,748 Views)
If you want to show the waveform all at once (like a scope has captured an entire waveform), use a Waveform Graph. If you want something scrolling, put the chart inside a for loop and outside of it wire the waveform to the Get Waveform Components, extract the Y array and wire that through the for loop to the chart. You could also get the dt from the wavform and wire that to a wait function inside the for loop and simulate the time it takes to capture the entire waveform.
(2,748 Views)
Due to your answer my problem is now solved. Thank you very much.
(2,748 Views)
