report generation in Excel
Hi all,
            Im new to LV, i want to learn to create an excel sheet using LV6.1..or LV 7.1
I saw a tutorial here at NI zone http://zone.ni.com/devzone/cda/tut/p/id/3178#toc2
they have included the tutorial files also as llb files
1)Do i need to install the llb files first ,before using it,to be in a proper way?
2)the llb files when double clicked reported many missing vis..
Should i need to have the report generation tool kit from NI to create Excel files? I ve got a complete version of LV 6.1 CDs ,is report generation toolkit included in it? or should i ve to purchase it separately??How could i check?
 I can create html report in LV 6.1 & ive created it,but icant see any excel supporting VIs in the report generation palette there..
can somebody help??
Stephen
(2,978 Views)
HI,
You dont need to install llb files, you can directly use that.
In this library some code is missing or wire is not connected properly.
Do the folowing modification so it will work fine. Unzip sample_tutorial_code_lv60.zip and open Simple Test Station - Design 4.llb
1. Open Simple Test Station - Design 2.vi from Simple Test Station - Design 4.llb and do the modification shown in attach sanp1.jpg
2. Open Simple Test Station - Design 1.vi from Simple Test Station - Design 4.llb and do the modification shown in attach sanp2.jpg
3. Before running the Simple Test Station - Design 4.vi give the path of excel sheet available in unzip folder
Hope this helps
Santosh
(2,973 Views)
Stephen,
Yes, you may need to purchase the RGT seperately, if you dont have the NI Dev Suite edition. LV 6.1 CDs alone do not contain the RGT. It is licensed & to be purchased seperately. Please contact your local area Ni sales representative.
That said, w/o the RGT, you can use ActiveX functions (Properties & Methods) from within LV to generate & customize (to some extent) Excel reports.
- Partha ( CLD until Oct 2027 🙂 )
(2,959 Views)
