report file name error with Chinese Date format
I am seeing an error at step Write UUT report in the standard model files.  This step is calling the API method save on the object Runstate.Report.
The issue occurs on computers using chinese localization with the date in the report file name.
Is this a known issue?  Is there a way to modify the filename before calling the above method to eliminate the problem?
(2,677 Views)
This forum will be addressed on the TestStand forum.
Mark E.
(2,648 Views)
