replace string
hi all
 i have a string and i want to replace all the zeros (numeric '0') at the end of the string to be removed meaning that  if the string has zeros at the end i juss simply want all them to be removed. for example  if the string is 'asds60dffa890sfaf000' then the output should be 'asds60dffa890sfaf' and if the input is only "12qwadfe00afer0adsf' then the output should be same as the input since it doesnt have any zeros at the end.
Regards
(4,156 Views)
This should do.
(4,149 Views)
Hi there
you can also use regular expressions. See attachment.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,142 Views)
Much better than mine, i admit..Smiley Happy
(4,133 Views)
This site has helped me understand Regular Expressions.
The expression "0*$" means:
  • 0 = find a zero
  • * = repeat the previous item zero or more times
  • $ = match at the end of the string
Jim
(4,102 Views)
Be careful with regexpr, because most each editors and IDEs have their own definition and syntax of regexpr.
To be on the safe side right click the "match pattern" function and open the LabVIEW help for details.
Best regards
chris
(4,094 Views)
thnx everyonr all the things have been very helpful
thnx a lot
Regards
(4,050 Views)
