replace array subset?
Could someone please explain why this doesn't work? I just need to replace a certain element in a byte array with new data.
Thanks.
(2,846 Views)
hi
your code is not working because you have given empty array as  the input to the Replace array subset function.
first give some values in the array and then replace at the particular index.
If you want to insert value in new array use insert array function instead of replace array.
(2,824 Views)
