repeated software triggering
hi
I want to repeatedly record data using a software trigger. I used the acquire N scans analog software trig.vi example and adjusted the input paramteres for my needs. For one aquicisition the vi works fine. Now i want to repeat the triggering and recording process because i want to do averaging. i tried to use a for-loop or a while loop as shown in attachement, but i get errors.
does anybody know which adjustements i have to make to get the vi running ?
Thanks Philipp
(2,825 Views)
and here is the attachement .....
(2,824 Views)
Hi Philipp,
try placing the "AI start"-VI outside the loop. Otherwise LabVIEW will try to start a task that is still running and that´s
just what your error message says. I didn´t have a device that runs with the traditional DAQ so that i couldn´t test but
please let me know if this could solve your problem.
David
(2,777 Views)
