06-07-2006 10:16 AM
06-08-2006 04:17 PM
Hi versace,
The Help files for the ANOVA VIs were really beefed up in later versions of LabVIEW and even include some examples. I think that they might contain just the information you need.
Check out the 1D ANOVA, 2D ANOVA, and 3D ANOVA Help files.
I hope this helps! Let us know if you have other questions.
Megan B.
06-20-2006 12:19 PM
03-05-2007 07:49 AM
Hi all,
I have a problem with 2D ANOVA.
I have 45 measurments of something, for 5 parts, 3 repeats of measurements, by 3 dudes.
I keep having an error -20043 (and anther time -20045) (this mean "The level of factors is outside the allowable range of some data" and "The total number of data points must be equal to the product of levels/each factor * observations/cell. ")
I am not to sure what values to put for "observation for cell" "B level" and "A levels"
the out put array with info is void!!!
Please help it's really important.
I use LV 8.2 and the Help files didn't helped me 😞
Thanks in anticipation.
03-07-2007 06:09 PM
Hi Hapenciuc,
So I read through the help file as well. They didn't help me either, but I don't know much about ANOVA much less 2D ANOVA. Do you think this is an error in LabVIEW or just need to know how to implement it in LabVIEW. Have you tried your data in Excel (pretty sure it has an ANOVA function), and gotten useful results?
Also I put an indicator on the the info output and got a 2D array. Did you get something different?
03-08-2007 01:31 AM
03-08-2007 08:12 AM
