rename the title for each imput into write in measurement file
when i use the write in measurement file, each column of the results appears untitled in the excel file, so i want to have a title specific for each imput.
any one have idea?
(3,207 Views)
Hello SALAH.H.M,
You shouln't use Express VI if you want to customize your excel file construction.
You should lock in the LabVIEW exemple how to save a mesurement on file by taping the keywor excel.
You will find attach to this answer some example.
https://decibel.ni.com/content/docs/DOC-7660
Best regards
Sabri JATLAOUI
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,155 Views)
hi sabri.jatlaoui,
the attachement file didnt open because you use the version 12 but im using the 11.
Can you send me it as a picture?
Tnx
(3,151 Views)
I saveit in LabVIEW 2011.
Best regards.
Sabri JATLAOUI
(3,147 Views)
Thank you very much sabri.jatlaoui,
i took your solutions concerned toTDMS and TXT files .
and for how to title the columns at EXCEL files using write in measurement file structure,  i found the solution and i want to give it you :its the attachement file.
TNX
(3,126 Views)
Hello SLALH H.M,
I'm glad that you found the solution.
Best regards.
(3,099 Views)
