removed random amount of extra spaces from string
Hello i am getting a string input that sperates a data table with a random amount of spaces.
Is there a way to replace All space sequences with a single space ?
e.g.
CPU        MEM  PID
15.689    12.2   6610
21.8         156    6611
(so the spaces are random)
I have ried replaces double spaces with single spaces a total of 8 times in succsession but for some reason that is also removing (some) single spaes as well and im not sure why.
(5,712 Views)
Accepted by topic author Ace-Scottie
You can do this with a single Search and Replace String.  You need to enable Regular Expressions for this function (right-click the function, choose Regular Expression).  The Regular Expression " +" (space followed by a + sign) will match one or more spaces -- wire this into the Search String.  Wire a single " " (space) into the Replace String,  Set "Replace All" true, then run the function and it will replace all multiple spaces (in the current line) with a single space.  If you want it to handle multiple lines in the string, enable that option as well.
(5,680 Views)
"Scan string for tokens" by default treats multiple consecutive delimiters as one. That's what I would use here because it also eliminates the "spreadsheet string to array" you seem to be using later. Do it all at once!
(5,668 Views)
