remove unit in array
In the attached VI, I am in trouble with Hz. How can I remove it?
Thank
(3,879 Views)
You can just select that Hz and delete that what is the problem?
(3,875 Views)
Right Click in the Frequency control and deselect Unit Label from Visible items.
Hz will disaapear.
______________________________________________
Kudos are welcome
(3,865 Views)
Hz will disaapear.
Except that the numbers will still have a unit associated with them. If the user doesn't want a unit then they have to select the text and delete it, not just hide it.
(3,863 Views)
Even you cannot do normal mathematical operation with other numeric values when you have a unit on them. So if you want to show the unit just add it as a decoration.
(3,851 Views)
