remove partial header information on write to measurement file vi
The data is generated using the write to measurement file express vi and i would like to remove all the header except from
x_value voltage_0 voltage_1 voltage_2 voltage_3 and etc onward
please kindly help me on this as i kinda new to labview
(3,084 Views)
i too came across this!!! i opened the express vi and digged into it and found the place where this channel names are written Smiley Happy and then gave the channel names that i require as input (for lvm format) might not be the right way of doing, there may other way, but it works as expected!!!!Smiley Happy
Kindly post if anyone has found a different way of doing this.
Message Edited by JK1 on 03-24-2009 11:29 PM
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,073 Views)
 While configuring the Express VI you have an option called no header. check mark the option u will not get any header information. There is no option to remove some header information while configuring the Express vi.Otherwise you need to digg little deep to remove these things(as JK told).
Message Edited by Baji on 03-25-2009 10:21 AM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,070 Views)
Well, what Balaji mentioned is right.
From my experience, if I wish to customize a format, I'll use write to text file.
You can find an example from Help>>Find Examples>>Fundamentals>>File Input and Output.
(3,032 Views)
Hi Tjety,
Is your problem solved? If so please mark the post (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
(3,005 Views)
