remove index from arrays in cluster
Labview forum,
I have a cluster which contains both array and non-array elements.
Each array should be the same length.
I would like a function which removes a specified index (or index list) from each array in the cluster but leaves the non-array cluster elements untouched.
Attached I have attempted to write this function as generic function without prior knowledge of the number of arrays within the cluster.
I have tried to use references but encountered a problem where I cannot access the data of the arrays inside the cluster.
Any help?
Jamie
Using Labview version 8.0
(3,115 Views)
Hi Jamie,
in the "cluster & variants" palette you will find functins to convert the variant data given by the value-property node back to "nice" array data...
One more tip: Give unique names to those arrays.
This way you can also (easily) decide which representation to use for the array - you need this information in the variant conversion process!
Message Edited by GerdW on 09-24-2007 09:59 AM
(3,105 Views)
Hi GerdW,
Can ypu please back-save the VI for 7.1 ?
- Partha ( CLD until Oct 2027 🙂 )
(3,096 Views)
Hi Partha,
here it comes. I just added the "variant to data" to the original vi...
(3,089 Views)
Thank you, GerdW.
(3,073 Views)
