remove blanks 1d string
Should not matter about the version.
Double check the input string to make sure there are actual spaces there.
Message 11 of 24
(1,877 Views)
they were numerical '0's before being converted
Message 12 of 24
(1,872 Views)
Hi john, i have attached a vi.
Hope i will be usefull for you.
Thanks.
CLAD
Labiew programmer
Message 13 of 24
(1,860 Views)
ta, i'll have a look what i've done wrong when the kids have gone to bed later 😄
Message 14 of 24
(1,859 Views)
hi could you save it so i can read it in LV 8.2? cheers.
Message 15 of 24
(1,843 Views)
rather oddly, found a way around the problem, after realising it was the space it wasn't looking for, i replaced the space that i inserted earlier in the program with a capital 'a' this would appear different in the text, so i could remove it. then did the remove on 'A' and walla!
It now works.
weird!
Message 16 of 24
(1,833 Views)
Not sure you would want it. Looks like a search and replace before LabVIEW had a native function for it.
Message 17 of 24
(1,827 Views)
well it works after a series of tests.
cac-handed was of doing it, but it seems to be ok, the text doesn't us capitals so a capital A will do for the search and remove. its a 65 numerical before conversion.
Message 18 of 24
(1,816 Views)
John Pierson wrote:
and walla!
It's spelled "voila" and it is pronounced like vualla.  That is your French lesson for the day.
- tbob
Inventor of the WORM Global
Message 19 of 24
(1,778 Views)
I have a problem with blanks spaces in my VI that I cant get rid of IT!
I have a smal table of string, that keep the table format but I need a 1D format to send to the machine!
The Labview seems not to recognize the blank spaces to delete with the string tools.
attached is the VI.
I know it is simple but I tryied many ways!
so , thank you in advantage
regards
Leandro
Message 20 of 24
(1,686 Views)
