remove array elements
Hi All,
connect to variant was a cluster of 3elemtents and yet, to my xy chart buffer, is a cluster of 2elements. How to connect them up?
Thanks & Regards,
Isa
Message 1 of 8
(4,431 Views)
Hi Isa,
can you show a picture of your data, please? Can you also show the expected result?
Try to help.
Mike
Message 2 of 8
(4,429 Views)
Sorry that i forgot to attach the picture. haha XD
Isa
Message 3 of 8
(4,426 Views)
Hi Isa,
which values are in your 3 elements cluster and how do you want to assign them to the 2 elements cluster? You can use a for loop to run through the array. Use a unbundle and a bundle function to build a 2 elements cluster as you need it.
Mike
Message 4 of 8
(4,420 Views)
The elements are: 2 of my subvi in DBL and one in timestring. [3 elements cluster ]
when i assign them, in update graph 1, there will be 1subvi DBL and timestring [2 elements cluster]
How to i place my for loop? when i straight away values into the bundle and comes out a brown wire(cluster).
Regards
Isa
Message 5 of 8
(4,412 Views)
Hi Isa,
i don't know how you come from your Cluster with 3 elements to variant and why you try to convert it back to array of Cluster of 3 elements. The attached picture shows how you can use the unbundle/bundle function.
Hope it helps.
Mike
Message 6 of 8
(4,404 Views)
i would like to ask why does a for loop can do this job? by remove array elements.
Thanks & Regards,
Isa
Message 7 of 8
(4,337 Views)
Hi Isa,
what do you mean? The for loop runs as often as elements in the array. If autoindexing is on, then you can directly use the single element.
I recommend to visit some of the free ni courses.
Mike
Message Edited by MikeS81 on 01-22-2009 08:16 AM
Message 8 of 8
(4,329 Views)
