remove a row of strings from a 2d array
I have a VI that outputs a excel style 2D array of strings. Sometimes there will be empty rows in between two or more rows of information like below:
[IMG]http://i45.tinypic.com/mmaezd.png[/IMG]
I have done a lot of searching and cant find a solution, how can I delete the empty rows in order to squeeze the information together?
(7,152 Views)
I found a post discussion the method to delete a column or a row.
http://forums.ni.com/t5/LabVIEW/how-to-delete-columns-from-a-2D-array/td-p/1450846
This works fine for your problem.
You just have to compare the First Element of every row to a EmptyStringConstant.
If the First Element of a row is empty you can delete the row.
To check the whole table place it into a For-Loop.
regards,
adigator
(7,147 Views)
Here is an example using a shift register to store "good" rows, and a check to see if all columns in a row are empty.
This is a snippet, save to desktop, drag onto VI.
I used reverse logic for saving to the storage array.
Mark Ramsdale
(7,135 Views)
If your data sets are very large, try to do this without hitting the LabVIEW memory manager.  Given that you are deleting rows, this is fairly simple using a bucket brigade algorithm.  I posted an example of this using elements in a 1D array here (see fourth example).  It is equally valid for rows in a 2D array.  Performance will be orders of magnitude better than the simple solution.
(7,111 Views)
I have been working for a couple of days to get this to work. Your snippet finally did it for me. THANKS!
(6,929 Views)
