04-14-2015 10:37 AM
Hi Guys.
I'm trying to remove some outliers from my data. I have the "Remove Outliers.vi" but I don't really understand how to use it in the Range Setting.
Could somebody please explain , how does the "Range Input" work, so I can remove the Outliers from my data. Please take a look at the attached image.
Thanks in advance for your help.
Kind regards
04-14-2015 12:49 PM
The LabVIEW help seems pretty clear on this one:
Range specifies the upper and lower bounds of the range. This VI removes data points that lie on or outside the bounds of Range. If range type is Y or X, this VI uses the first two elements in Range as the upper and lower bounds, respectively, for the given axis. If range type is X and Y, this VI uses the first and second elements in Range as the upper and lower bounds for the x-axis and the third and fourth elements in Range as the upper and lower bounds for the y-axis. |
For your specific case, you may need to do some manipulation to better identify what you mean by outliers (i.e. you may want to first calculate a distance function away from your spline fit and then remove items with distance greater than a particular threshold.)
04-14-2015 04:16 PM
