remote programming
I just come about Labview and I have not much experience using it. I would like to create a front panel that can control Advantest D3371 Transmission Analyzer. I have the Remote programming manual and I have no idea how to write the codes into Labview or VIs or any idea how to put it into strings. I can communicate with the instrument through GPIB and codes like *IDN? but complicated command reference like --> SOURce10:FREQuency[:CW]int which function as Set The Frequency. The Parameter is and query response format is NR1(interger type). The description of this code is to specify the frequency of the clock signal generated from the CLOCK OUTPUT on the SSG module rear panel. Setting range 10000kHz - 3600000kHz . Setting resolution : 1kHz and setting unit : kHz.
Is there any resources that have similar coding that i can use as reference?
(3,410 Views)
Hello
Download the driver from this web and see the examples.
Advantes D3371
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,406 Views)
Thanks for providing me the webpage but I had already tried a few times back and I think that the page don't support the driver anymore..
rgds,
al
(3,402 Views)
ooooops. Sorry about that
Try this:
http://www.rohde-schwarz.com/www/dev_center.nsf/frameset?OpenAgent&website=com&navig=/www/dev_center.nsf/html/nav,10,17&content=http://www.rohde-schwarz.com/www/publicat.nsf/article/n175_d3371
Clik on Transmision analyzer...>download area> drivers....and download the driver
I downloaded it from there.
Cheers
Alipio
(3,391 Views)
Thanks alot!
(3,383 Views)
