remote panel update problem
Hi
I have made measurement applications which include remote panel control - so far no problems.  But now for the first time happened this: On the display of measuring computer the temperature graph of two plots is ok, but on the remote computer's display only one plot updates correctly, the other stays a flat line.  I stopped and started the application again: sometimes all plots updated ok, sometimes not.  But it was allways plot 0 that failed.  Any idea what might be the reason for this?
LabView version is 7.1, Windows XP.
(3,252 Views)
Have you been able to solve this problem yet?
(3,111 Views)
Hi
No, I haven't solved the problem yet. I guess you are in the same situation - right? Or hopefully you have solved it.
(3,087 Views)
I recently posted a remote panels update problem, and was advised to check this:
It could help you, too.
(3,035 Views)
